TwinTurbo.NET: Nissan 300ZX forum - SOLUTION FOUND ... it turns out idiot me put one of the
Subject SOLUTION FOUND ... it turns out idiot me put one of the
Posted by The Devils Z on April 22, 2008 at 8:34 PM
  This message has been viewed 322 times.
In Reply To Hey Devil, had the same weird problem too... posted by escturbo on April 22, 2008 at 06:45 AM
Message hard pipes clamp behind the TPS ..as the motor increase RPM, the screw would press against the TPS and move it occassionally ..didnt happen all the time .. hence intermittant ..I adjusted the clamp so that the screw is above the TPS ...reset the TPS with ignition on and car off to .46v ...high idle is gone ...
I hope this helps someone down the road troubleshoot high idle issues as I feel I covered all options ...
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
